Caporegime
- 8 Jul 2003
- In a house
Right as title, total noob here when it comes to routers as never used em before, right i got my Netgear DG834G router from AOL the other day as i regraded to the 2mb Gold package, and now decided to give it a go.
Now im not using the software supplied (no way
) as im doing it manually, now when i connect it up, get the http:// in there i get the config screen with 2 options, one auto, one manually, can i just do the auto one, and then through there will i have to enter some of the settings ive got here in the booklet (as it says in there i may need to enter some, but not all), or do i have to select the manual option and do it all that way.
Any help would be great.
Thanks.
) as im doing it manually, now when i connect it up, get the http:// in there i get the config screen with 2 options, one auto, one manually, can i just do the auto one, and then through there will i have to enter some of the settings ive got here in the booklet (as it says in there i may need to enter some, but not all), or do i have to select the manual option and do it all that way.Any help would be great.
Thanks.
