Total Upgrade
30 Oct 2006
Hi,
I'm looking to totally upgrade my home built desktop due to some recent purchases that can't be run to their full spec on my old board. Budget around the £250 - £300 mark unless you feel it would be future proof to up this a little more..
Currently:
Motherboard:MSI MS-6712 KT4AV AGP8x
Processor: AMD Athlon(tm) XP 3000+, MMX, 3DNow, ~2.2GHz
CDRw's DVDrw's and all the other bits!!!
Reason for change 1:
Memory - 2048 MB RAM. I purchased (2 x Gskill F1-4000USU2-2GBHZ 1GBDDR PC4000) but found i can only run them at 333 due to double sides or something...
Reason for change 2:
Want to update my GFX card from the ATI Radeon 9600XT 256Mb currently installed and have been advised to upgrade to the Nvidea 7600GT?? i think but someone mentioned PCI-E?? and i don't have it... only AGP i think.
So.... after all that... i'd like to buy a new motherboard that requires not much more than a plug 'n' play set up, that all the above can work on.
Also... when buying a new motherdoard... do i instantly fall into the trap of needing to replace the heat-sinc and fan and what about the little chip thingy it sits on.... that was quite exspensive .. do i need to replace that too???
Thanx in advance for any advice...
oooh.... anyone know of a good one stop shop for buying all this stuff??
Gavin
