Total War - Warhammer - cdkeys?
18 Oct 2012
Oxfordshire
Hey all,
Just wondered if anyone knows if the cdkeys are generally ok to order from. They have the above game for like £22 but normally I buy through steam?
I use them all the time, their support has been good the only time I've needed to use it too. In my view, they're no more dodgy than using the likes of greenmangaming. I'm planning on buying a key for total war warhammer from them too, I'm going to wait a wee while though, as I want to buy Xcom 2 and The Division from them first. Generally their pre-order keys don't fluctuate in price as much as their released game keys do. Guaranteed the price will go up come release time too.
Cool sounds ok then. Will give it a purchase and wait and see.
And if you pre-order you get chaos which why I'm looking at getting it now cause with all the other dlc costs that CA will have for this I can see it being £100+
cdkeys are quality, got a refund on xcom 2 within 5 minutes of asking as I'd found it cheaper elsewhere, always got my keys from them with no hassle
I dont think the CDKEY's one gives the Chaos DLC. They usually sell the pre-order key seperately.
I orignally almost bought the collectors being a fan of warhammer but at £100 with it not containing much more than fluff I decided to just do that instead!
Where did you find it cheaper? I'm going to pre-order it very soon.
Nuuvem seemed to have the digital deluxe pack for around £20 that includes the season pass but it says I can't buy it, not sure how to do the vpn trickery or if that would even work. Hard to find info on the net if the key would work :(
