I hooked up a quick and dirty cooler install to test a GTX280 with a waterblock and I was really horrified when I saw the temperatures in GPUz. After about 20 minutes the water-block was too hot to touch and I shut everything down. The odd things is that not only was the GPU block hot, the radiator was hot and the water pipes were hot.
This leads me to believe that the water-block was working correctly, but the radiator simply couldn't cope with the heat loading. Except it was a Feser TFC 360 with 6 fans on it.
Can anyone think of a reason why this should be the case?
The water fairly whizzes round the loop, so I don't think it's that.
I've not split the block open as it invalidates the warranty, but it does appear to be free-flowing ie. not blocked.
EVGA SC GTX280 with HydroCopper 16 block
XSPC Reservoir top fitted to 10W Laing DDC
Feser TFC 360
6 Yate Loon SL 120mm fans in push/pull configuration
Approximately 60cm tubing length (30cm each leg to from rad)
XSPC 3/8" ID tubing on DD High Flow 1/2" barbs
The radiator, pump and res are known to be good, only the graphics card is new.
I'm genuinely baffled.
Feser TFC 360
