Touch Screen Help - wont configure
22 Jul 2006
Morning All,
I have a 7" touch screen in my car:
Now the problem I am having is that it just wont configure, it was working absolutely fine on the last computer I was running, then I upgraded to a 3.0ghz P4 with 1gb ram etc etc.
Clean install, installed everything fine, the monitor was working well after I installed the software, and was working calibrated auto, but then it required a reboot & calibration (requires you to touch each corner) and ever since its been out by a few cm, and cant seem to get it to touch spot on.
Could it be the latest drivers a broken? http://www.touchkit.com/Drivers.htm
Would it be possible to use another kind of touch screen software?
Any help would be appreciated.
Thanks
