Touchpad Alternative....
Do not need a Tablet, however the hysteria over the TP has made the left hand side of my brain want one, however i have given up in getting one and am seeking an alternative...
Options...using my €100 on Fnac
or
a Hansspree
Vous êtes Français?
AndyPAD Pro? Quite cheap.
Do you have a budget as such? Or is a tablet all you want, money to factor? :p
iPad 2 - depending on what you will be doing.
Transformer - again, depending on usage, and if you fancy typing/or are currently typing a lot, the integration of the dock is great and would work perfectly with a busy life style.
Galaxy Tab 10.1 - again, usage, and price point.
There are also quite a few alternatives, like the AndyPAD Pro, then there is the likes of the Advent VEGA, running Android 2.2 as standard (probably get a gingerbread/honeycomb port for it)
Also the Original Galaxy Tab. It still is a decent specced tablet, will do most things as it runs Android 2.2 and i know there are ports for honeycomb (i also think there is an official release of gingerbread for it :p)
Also, that link has EXPIRED, meaning the deal won't be available from HotUKDeals.
Vous êtes Français?
Cheers for reply:-
Budget around €170-€250. Would add the €100 FNAC voucher on top of that.
Have a laptop so this is a like to have that need to have purchase.
Requirements:-
Web Browser
Decent access to apps.
Access to BBCq/4OD
Decent bit of disk space.
Ability to watch films on the device.
WIFI
Like to have
3G
Cheers for reply:-
Requirements:-
Web Browser
Access to BBCq/4OD
WIFI
Like to have
3G
Samsung Tab 3g then. Plus you can take it out with you since its not that heavy.
Definitely wait a few weeks.
Also screen issues are slightly fixed. It still isn't using a very high quality LCD or IPS screen.
Screen is awful on the Vega, a pretty important feature for a tablet.
I have used a Xoom and an iPad and whilst the Vega falls quite a bit short of those two in terms of screen quality I certainly would not call it awful.
I am running the Vega now with the latest build of HC 3.2 and it is fine for what I want the tablet for and for what I am willing to pay.
