Towing help
13 Oct 2006
Surrey
Head gasket has gone on the car and it needs towing to the garage, about 2 miles away.
I've just tried steering and braking without the engine running and quite frankly I dont know how I'm going to do it! The brakes are really poor without the engine running, worryingly so. Steering I think i can handle however.
Would it be safe to turn the engine on? It would only be idling the whole way
Cheers!
How far gone is the head gasket? Its going to be getting new oil and water as part of the replacement and it shouldnt overheat in 2 miles...
If it was a choice between idling while towing or driving it, I'd be driving it...
I've never had a problem with braking with a car thats not running - what car is it?
To expand on my previous comment.
Once you are actually moving, the steering will be fairly light anyway... well, not quite as light as usual, but still easily light enough to use for all but the weakest of children. Power Steering really was designed for assisting with low-speed turning.
Brakes won't be quite as good as they won't be assisted - but you'll just have to press a little harder than normal, but then when being towed, you won't be doing high speeds and sudden braking, you'll be driving at a much slower pace and trying to keep moving as much as possible.
OK cheers for the reassurance! Just dont fancy wrecking my dads car :p
Gonna have to be firm with the brakes then it would seem
I trust that you're actually using a tow-pole and not a tow-rope since these are now illegal?
[Edit] Maybe not directly illegal, but certainly may end up with you being pulled over
As the car that's being towed, you're responsible for the majority of the braking, including to ensure that the rope/pole doesn't go slack.
When I was last towed, I was on the brakes WAY earlier and more often than the towing vehicle!
Unscrew the cap on the header tank slightly so it's not sealing. This will prevent excessive pressure building up in the cooling system.
This reminds me of when i towed my mates GTI-6 with the works van on a single man tow, god that wasnt fun. car was stupidly low tho
Well an update: Got it there eventually, despite the towing hook coming detached twice, at the worst possible points (village centre!) -caused a huge tailback :p
