TP-LINK Deco wifi with VPN
16 Sep 2009
Loogabarooga
Has anyone added a VPN to their TP-Link Deco wifi? I was looking at getting a VPN for my desktop but see it can be added directly onto the mesh wifi?
I'm not sure what you're trying to do. You can't put VPN on a wireless network, they have nothing to do with each other. VPN is something either your device does as a client based connection, ie, NordVPN. Or, you configure your router/firewall to host a VPN server. Some also allow you to dial a client connection from the firewall/router as well as being a server endpoint.
On the TP-Link APP, it allows you to add a VPN onto the router by way of a token and then applies to any or all of your devices connected to the router.
