TP-Link TD-W8950ND & Wireless Security Issue
28 Mar 2005
Drunken badger punching
I've just bought the router mentioned in the title, and I'm having trouble setting it up.
I've managed to get internet up and running via wireless, and configured it for o2 (possibly by fluke), but I can't set a wireless security key. I can get into the menu, select WPA/WPA2-PSK and assign a key. Once this is done, the 'Save/Apply' button is clicked, and it asks for the router to be rebooted for the changes to take effect.
The reboot completes, but the network remains unsecured, and upon re-entering the router setup, 'Security' in the setup menu shows the 'Disable Security' option checked. It seems to forget I checked the WPA/WPA2-PSK option.
Any help would be awesome, as I can't work it out at all.:confused:
