- 17 Jan 2006
Hi
I've got myself a TL-WA850RE wifi extender to give better wifi coverage upstairs in my house.
I quickly set it up on Friday using wps which seemed to work fine until this morning when various devices were having issues whereby al though they were connected to the wifi they had no internet access.
After a quick look on the devices I realised that the issue was that they had been given incorrect IP addresses. Instead of 192.168.1.xx they had been given 192.168.0.xx addresses.
A quick google showed this to be a fairly common problem and one that needs to be addressed by manually setting the extender up.
I read that I should give it a static IP address and tinker with the DCHP settings on the extender. The advice I've read on what to do with the DCHP has varied a bit. some places saying to disable it, overs saying to set the gateway and dns servers to the address of my router.
This morning I set the IP to static and disabled the DCHP and now I cant get logged into the extender. I know I have to connect to the extender's wifi to be able to connect to it but when I try to connect it fails to authenticate and obtain an IP address and hence I can't then connect to the extender to try any other settings. So now I'm not sure what to do.
Has anyone else set on of these up successfully or got any advice on the best way to set it up?
