OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
TPCast have now officially started allowing us to take pre-orders for their wireless adapter for the Oculus Rift!
Check it out below!
I'll update the links to product pages once the page is live on all our caches!
TPCast Wireless Adapter For Oculus Rift @ £349.99 inc VAT
tpcast wireless adapter for oculus rift, without video distortion, two-way interaction, ultra low latency
only £349.99 inc vat.
ORDER NOW
Experience something you never have in VR before! Experience total freedom. Freedom to walk and meander through a beautiful landscape, freedom to spin and turn and jump!
TPCAST Wireless Adaptor for Oculus Rift is an accessory developed specifically for Oculus Rift. It enables Oculus Rift owner and users to easily upgrade their Oculus Rift to a wireless VR HMD. With highly optimized antenna array and large bandwith, it ensures the display quality is the same as that with a cable.
Features
• Easy to Install: The TPCAST adaptor replaces the Oculus Rift cables following a straightforward and easy installation.
• High Resolution: The transmission delivers up to 2k display resolution and provides an extraordinary virtual reality experience.
• Immersive In-Game Experience: Getting rid of the Oculus Rift cables enables 360 degree of free movement.
• Long Battery Life: Battery pack provides up to 5 hours of operation.
• Extraordinary Comfort: The TPCAST wireless Receiver, attached to the Oculus Rift is very light and small.
• Near Zero Latency: The adapter adds less than 2ms latency assuring a seamless VR experience.
• Two-Way Interaction: Signals are transmitted back and forth between the PC Transmitter and Receiver.
• Broad Signal Coverage: Signals can reach up to 5 meters with a 360 degree angle.
Without Video distortion
Two-way interaction
Ultra low latency
More information to follow SOON!
HMD Receiver
Length:95mm
Width:90mm
Height:20mm
Weight:90g
Color:Black
Audio&Video Wireless Transmission Performance
Video Format:HDMI2.0
Video Resolution:2K (2160*1200)
Video Frame Rate:90Hz
Audio Format:16bit 44100 Hz
16bit 48000 Hz
Transmission Delay <2ms
Transmission Range>5m 360°
Power Consumption :4W
TPCAST HD Video Wireless Transmission Protocol
HDMI Interface :1
Standard USB Interface :1
PC Transmitter
Length:100mm
Width:60mm
Height:50mm
Weight :95g
Color:Black
Video Format:HDMI
16bit 48000 Hz
Output: Standard DCIN Interface : 1 DC 5V 1.5A
Standard USB 2.0 Interface:1 DC 5V 1.5A
Input: Standard USB 2.0 Interface:2 DC 5V 2.1A
Battery (Standard Version)
Length:166mm
Width:58mm
Height:22mm
Weight:350g
Color:Black
Standard USB 2.0 Interface :2 DC 5V 2.1A
20000 mAh Lithium Battery Battery life >5h
Product Accessories
• Cables *3 (Video/Data Cable, HDMI Cable, Ethernet Cable )
• Router, Power Adapter
• Nylon bag, Belt
• Quick Start Guide, Warranties
Check it out below!
ORDER NOW
Features
Two-way interaction
Ultra low latency
HMD Receiver
Length:95mm
Width:90mm
Height:20mm
Weight:90g
Color:Black
16bit 48000 Hz
HDMI Interface :1
PC Transmitter
Length:100mm
Width:60mm
Height:50mm
Weight :95g
Color:Black
Video Format:HDMI
16bit 48000 Hz
Length:166mm
Width:58mm
Height:22mm
Weight:350g
Color:Black
Product Accessories
• Nylon bag, Belt
