TPMS fault after new tyre fitted
18 Oct 2002
Riding my bike
Had to have a tyre replaced due to a slow puncture in the side wall would result in TPMS light coming on after about 36 hours after putting more air in.
Took the wheel in to ATS and then picked it up with the new tyre on and fitted it back on the car, checked all 4 tyre pressures and thought "done".
Next day drove the car expecting the TPMS light to go out (NB one light on dash - no display showing which tyre is low). Light stayed on and after about 3 miles started to blink. Owners manual says this a TPMS system fault, NOT a low tyre.
Spoke to ATS this morning, they said that normally they would get me to bring the car in and would check each tyre's sensor in turn. But their TPMS reader is broken and they have been waiting 2 months so they aren't really in a position to help.
Now the car is 8 years old and has only done 34k so it is possible that the TPMS battery is getting flat, but it seems like one hell of a coincidence that it choose now to go flat. My guess is that someone knocked/damaged the sensor when changing the tyre.
Could changing the tyre cause the sensor to use up the last of it's battery? Could having the sensor out of range for 48 hours cause it to use up battery faster or need to be reprogrammed to the vehicle?
Any ideas?
ATS is a big brand right? If that branch's TPMS reader is broken, get them to organise using another at a neighbouring branch.
Just got back from exactly that. The TPMS sensor in the wheel they changed the tyre on is not sending. battery status on all the others was "OK"
I'm guessing that the sensor was damaged changing the trye. I'll go back to the original branch and talk to them.
It’s extremely easy to damage a TPMS sensor when replacing a tyre, especially if the fitter breaks the bead of the tyre directly where the valve is.
It’ll either crack the sensor or snap it right off the valve.
Useful to know. I'll go and see them tomorrow and have a chat.
Well update - they took the tyre off and the TPMS module is undamaged - I have it infront of me as I type.
So next question - Hyundai want £240 to put in a new one which is madness.
Any suggestions as to aftermarket ones - idealy that can be fitted by an independent with the right equipment. Or - has anyone had any luck with "pre-programmed" ones that claim to automaticaly connect to the car?
We fit aftermarket ones and code them in if required, which we get from a variety of local motor factors.
Any half decent garage should be able to help you.
I've sent the original sensor id to an online place that says they can clone the original.
Hopefully that will mean a simple fit with no programming.
