TPMS: Headache for tyrefitters
JKD
JKD
27 Jun 2004
Hey all,
Picking up a new Merc on Friday and it appears to come with full TPMS rather than a passive system. Luckily from my old car I have a set of winter tyres that are the correct size.
Mt question is, will the fact that I have TMPS cause a headache for tyrefitter (and expense for me) if I bother to have the winter tyres put on this year?
Cheers for any of you with experience of this.
It shouldn't. The device is normally fitted to the wheel (inside the tyre area), so need to touch it.
When you restart the car it can take a few moments for the TPMS to pick up the reading again, but you should be fine.
(From my experience in an Insignia).
Ah OK. For some reason I thought the device was fitted to the valve stem and usually tyre fitters replace the valves.
It is - but this simple means the tyre fitter doesn't need to replace the valve. In theory it should be cheaper for you as no new valves are required but we all know that saving won't be passed on :D
The bigger problem is of course for you - your old wheels won't have the sensors fitted so if you intend to use them you'll need to either purchase a set of sensors or put up with constant warning messages.
Ok sounds good.
I'll. it be bothering with a spare set of rims at all this time round, so I should be fine.
Thanks all
Had no problem swapping mine over to new alloys + tyres.
I did ask before I ordered them and they said it wouldn't be a problem but some places refuse to touch them as they are easy to break compared to a normal valve?
the only issue potentially is if they hit the sensor with the tyre/tyre iron when fitting the new tyres, but any tyre fitter worth their salt shouldn't even touch the sensor let alone break it.
iirc the systems merc use are pretty tough cookies anyway.
Yep, even my son's little baby Kia has a basic system that just lights a dash indicator if there is a problem. No other info given though!
neither the us or the eu regulations specifically require sensors in the wheels though, systems such as the ones vw use that involve the traction control system are just as valid.
Not true. The US regulations at least specifically require pressure monitoring not flat tire monitoring.
I suspect the EU regulations are similar as just before they came in BMW made the full pressure monitoring system standard fit despite the ABS sensor system being fitted already for years..
