Hiya,
I've been reading up the stickies in the forum and found this thread on search, but I've still got a couple of questions if anyone can help?
First off - What is the "normal" overclock you'd expect from the E8400? I've
heard 4GHz is pretty easy to get?
Secondly.. I get the idea that you bump up the FSB and test, but the thing which worries me is stepping up the voltage. Is there any way of calculating how much extra voltage to apply or is it all guess work? And IF you under/over volt the chip, what are the consequences?
Is it just a case of step the voltage up tiny bit by tiny bit until it's stable? But can you fry something?
Not too many questions I hope
Never did reach 4Ghz stable) with some setting changes.
