I suppose this is case related in a way , if not please move it !!
I’m in the middle of building a 939 system, for er indoors, in a PC7+ (Black of course as silver is the devils work)
and I purchased a TR-3 temp/fan controller thingy. Having never fitted one of these before , simple question really , how on earth do you connect this thing up as the instructions are dire !
Where do you connect the temperature sensors , one to the base of the cpu heatsink is about all I could work out !!! Do the other two go near to the board chipset and RAM ?
As for the fans am I missing something ?? I take it I have to unplug the supplied 3 pin connectors from the TR-3 as they terminate in 3 pin female and are for extension purposes ??
Do I plug the 2 120mm case fans and the CPU fan into the TR-3 , or leave the CPU fan plugged into the board (Lanparty Expert) ?
Gonna take ages in cable tidying as well
Lovely case the PC-7+ by the way
