Well my temps were rather high first time I installed this new cooler, and after some cable management and lapping I have managed to get it around 10 degrees down - so that is nice
But that HS should it be able to "wiggle" on the cpu, I feel I can slide it a little to the left and right after it has been fitted very hard...?
so I might need to see if some washers will do the trick...
