Hello,
I was waiting for the 2950x when I saw an offer in OC (B grade) for a x399 + 1950x that it is worthy to consider (I will call tomorrow to confirm the conditions of both of them).
I am looking for a silence computer with 32GB Ram minimal over Linux OS. I have set the following configuration:
And these are my questions:
- AMD TR 1950x
- Asus Rog Strix x399
- Team Group Xtreem 32GB DDR4 PC4-25600C14 3200mhz
- Samsung 970pro 1TB (I already have it)
- Corsair HX750i Platinum
- Noctua NH-U14S TR4-SP3
- Lian Li PC-011 Dynamic
- Is the memory ok for this motherboard (not listed in QLV in memory or motherboard)? Being b-die should be ok, but you never know. Any other option? I was looking for the 4x8GB Gskill 3200 C16 but it is not currently available (and C14 is 110 pounds more expensive than Team)
- Is the size of the memory compatible with the Noctua? I was thinking to take the Enermax 3x120 instead but I read in the reviews that it is noisy. Opinion?
- Power supply... I was looking for something cheaper with 650W and not noisy, but I couldn't find anything (something like the RM650; but it is not available right now)
- I couldn't find any passive graphic card that supports 4K screen (Nvidia if possible)
