Traffic lights but no stop line - confused.
17 Feb 2006
Winchester
I was driving along this A road for the first time Thursday morning and there were a set of part time traffic lights up ahead, which were in operation at the time (830 am). I started slowing down as it changed from green to yellow and there was a few cars ahead. I carried on slowing down forward thinking I would see the stop line ahead so I could stop but there wasn't one! By that time, I had virtually crossed the lights, which may have turned red in the meantime, and it was too late to stop so just carried on.
It got me worried I totally missed the stop line, but I checked on Streetview and it looks like it was deliberately erased. I drove back the opposite way that evening, and it is the same thing.
First time I have come across this - is not having a stop line legal/normal?
https://www.google.co.uk/maps/@51.0...!1e1!3m2!1suyP_lDLN6KwHgvrT6Wtk_A!2e0!6m1!1e1
I wonder if it's because they are only "part time". Like when you have to stop at a sign for temp traffic lights, there is no line then either.
No come across it before though.
In 2012 the Traffic Signs Regulations was amended and a stop line is now only needed if deemed necessary by the local authority, if no line is present then you should stop level with the traffic lights. You wont see if often as local authorities are now encouraged not to use part time signals
Not sure why you need a line to tell you where to stop.... The lights are at red, stop at the lights :confused:
Do you need a line to tell you where to stand to pee? :p
Because at some junctions you need to pull up short of the lights so HGV's and buses coming from your left can make it round the corner.
Agreed the usually the line is at or before the lights, but they are there for a purpose. If traffic lights were enough to tell someone to stop, why bother painting them everywhere else there are traffic lights?
If the rules changed a few years ago, I had no idea. I am not sure how you're supposed to find that out. :confused:
I'm with Richie.
You've got to be brain dead to see the lights go red yet drive through them because there was no line telling you where to stop.
How about engaging your brain instead of the clutch!
Yes, and at those junctions there are painted stop lines but to drive through lights just because there is no stop line, or be confused enough not to stop because there is no line, is just daft.
Ah. The hursley lights.... Just don't drive through them when they're active :D which is 7-9am and 3-5pm I think. Peak times mostly. They've been there for years and when I've had to stop I just stop at the first set and use the one from the middle island as the indicator as to when to go.
Why not???
On the face of it, they seem a good idea to me (Lights on when traffic is heavy to give joining/turning traffic a chance, off when traffic is light and opportunities for joining/turning arise naturally)
Why not???
For T-junctions and roundabouts, traffic lights should all be part-time IMO. There's literally no point in them being on at say 2am when you're the only car around and you have to stop. I could simply approach the junction/roundabout like any normal one, and drive when safe.
Considering all the guidance on energy saving nowadays, it seems to be a rather large waste of energy to have these running at all hours all over the UK.
(Yes, there may be some places where this is standard, but the majority I see are on all the time)
Indeed this, although many drivers don't and then sit looking at you (the driver of the HGV) in a confused manner when presented with a truck inches from their car, unable to make the turn.
Alas common sense is lacking in many drivers.
No stop lines.. man if you think that is a problem, try driving over here. The roads are a complete nightmare to traverse, and that's without the chaotic drivers.
And if that is the case they will include a stop line.
Rule of thumb is stop short enough so that you can see where the sign enters the ground.
