Transfer cable for 360 help.
28 Feb 2004
North East, UK
Hey guys, my elite is going back as it keeps crashing and work are letting me do a HDD>HDD transfer, what I want to know is can you transfer from one elite HDD to other like you can with the 20gb>120gb HDD. Cheers.
All my saves/conent are on the old one and I would have prefered to use the newer dive, guess I will need a memory card then?
You can do 120gb -> 120gb but the transfer DVD you have might not be the right software version that supports it, the initial release would only do 20gb -> 120gb.
I would go with orderoftheflame on this thinking about it. Just keep the drive you have. If you are worried about the older drive failing, I wouldn't be. It's just as likely you would change to the new drive, and it would fail!
Thanks yeah it appears my software is older. Did they release a newer version that supported 120gb > 120gb? Thanks.
