Transfer data to memory sticks?
26 Nov 2004
Near Windy City, USA
Hope this is in the right area,
Just need to know whether or not you can transfer data i.e pics to SD or compact flash memory cards.
Is there a way to do this with card readers on the pc etc?
Basically want to store some of my favourite pics all on to one memory card - is this a possibility?
Thanks in advance
well this is really easy, just select all the pictures you want (if you want to select more than one pictures you can hold ctrl whilst clicking) and right click on one of them then send to then click on your flash drive!! couldn't be simpler!! hope this helps. :)
That simple huh ! :D
But i have not got a SD usb card reader at the moment - thats all I need to be able to transfer the data from the PC to the memory card right?
Cheers
yep, that simple, all you need to do is plug it into your pc via USB and it will install itself. windows should take you through it step by step. i don't know how many pictures it will hold, it depends on the size of the sd card and the size of your photos. any more questions then please ask!!
regards, david :)
