Transfer rate data ?
  • Thread starter Thread starter CSA
  • Start date Start date
CSA
CSA
20 Apr 2006
Lancashire
this probably bit of a newb question but is there a way to actually see the transfer rate of a file when moving it to one pc to another on a win xp network ?
at the moment it just tells me "4 minutes" or what ever , i know on vista you can actually see the raw data , is there a way on xp ?
There are many network bandwidth monitoring applications available. I use DU meter. :) Tells you the current bandwidth being used on your local connection.
