Permabanned
- 28 Dec 2009
- london
At one site we have a physical backup server with backup exec on it. It has a gigabit nic. All servers on the network seem to be able to transfer to this machine at relatively fast rate 15mbyte a second etc. But when copying from one specific vmhost it goes at 5mbyte a second. I have done some transfer tests and it is not a disk transfer problem as copying between disks on the array goes at full speed. Even copying between guests on the same vmhost. I even tried copying from one guest on the problem host to another guest on another host and the transfer speed was ok. It is just copying too the physical backup server from this vmhost that is very slow.
The host has two gigabit nic assigned to the vmnetwork that is in use by three guests, one of the guests is not used and the other is used for monitoring and is not heavily used.
Any idea how i can troubleshoot this problem? it kind of looks like a vmhost/nic issue, the vmhost is running esx 3 which does not help. Do you think a reboot of the host might solve the issue, any tips might help thanks
