Transparency Help
Si.
Si.
22 Oct 2002
Melbourne, Aus
Hi all,
not sure if this is the correct place, but I've got a logo for a website and I need to make the background transparent, how do I do this? I've not got a clue.
Thanks
What trip means is we don't have enough info to tell you exactly how to achieve this.
Do you have a rasterised jpg? A vectored .eps?
If its just a flat jpg then you need to cut out the logo using a lasso tool or similar and save as a PNG with transparency.
