Transparent Purple Spray Paint
16 Aug 2011
Sunny Lancashire
As the title suggests, I'm looking for a transparent purple spray paint for some Enermax TB Silence 120mm fans. The fan blades have a black tint to them, but are otherwise transparent, and I'd like to keep that look rather than painting them a solid purple.
So far, the only one I've managed to find is for graffiti store.thelondonvandal.com/products/molotow-belton-premium-transparent-400ml-spray-paint. Though to be honest, I don't know if it'll be okay on plastic.
The only other one I've found was for remote control cars and stuff, but apparently it can't be used on plastic.
Any suggestions? I'm going off my chump trying to find one.
