Does anyone have experience of transporting bikes inside large vans? The idea worries me because I envisage it falling over.
I guess you need to secure it properly.
Any advice?
Cheers,
Make sure you only compress the forks a bit and not fully down as sustained compression can cause them to leak past the fork seals.
if you have a bike get one. very useful for servicing.
i always use one in the van. put it on paddock stand in middle of van with front wheel against headboard. then strap it down or to the sides of the van with 2 straps at the front and 2 at the rear.
always done it this way.
alternatively put a quilt against the side of the van, lean it up against it and strap it to it. remember to strap the wheels to the side to stop the slipping out.
Right, gonna get hold of some ratchet straps.
Next worry is getting the bike into the van. What do people do, ride it up a thick board?
BINGO
When i didnt have one it took three of us to lift my CBR600RR in and out....heavy!
Cheers![]()
My friend had his RS50 carried in a Renault Espace.. but thats just a RS50 ...
