I need to drive my pc about 11-12 miles and it will have a h50 inside it...I don't have any of the case packaging unfortunately so should I risk t and how should I um prepare it?
I dont think you'll have any problems with the h50 seeing as the heaviest part of it is attached to the case not the mb. everything should be fine aslong as you dont turn too sharply. you may have to take out the graphics card depending on how heavy it is.
