Hi, I'm moving to my new flat tomorrow and I need to move my watercooled rig. Is there anything I need to do before/after transporting it? I'll probably put it in the footwell behind the passenger seat in my car, so it will be kept upright. Should i empty the water out first, or is this unnecessary?
Thanks for any advice.
If you're paranoid and you've got the time then drain it out. I wouldn't worry about it if you can't be bothered though.
