TRAP_CAUSE_UNKNOWN
18 Aug 2005
Shropshire
I get this errror every now and again whilst playing Battlefield 2.
BSOD Saying TRAP_CAUSE_UNKNOWN
I think it might be my systems instability but it only happens once in a while.
Please help me fix it :)
Many Thanks,
EDIT : Rams @ 201 Mhz, and 2T
Hmm, I haven't looked at a minidump before, but debugging one helps, maybe someone'll do it for you if you post your minidump from:
C:\WINDOWS\Minidump
NathanE said:
Upload the minidump somewhere and I'll take a look in a debugger.
Sorry to go off-topic, but NathanE what do you use for your symbols path? I've been following a tutorial thingy showing how to debug minidumps & it said to use SRV*c:\symbols*http://msdl.microsoft.com/download/symbols for the symbol path but they don't wanna work :(
EDIT
Nevermind :) - seems to be working well.
Thanks.
Just got WinDbg to work & it comes out with TeamSpeak.exe as the error for the crash in the 3rd of Sept.
Driver error apparently (usually is).
I'm not sure what it means by TeamSpeak.exe but first off try reinstalling TeamSpeak, if that doesn't work then maybe reinstall your sound drivers?
EDIT
I'll do the dump previous to 3rd Sept for you as well... I'll edit this post when I'm done.
EDIT
I get this (got the same for the 3rd sept dump as well):
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0x12
PROCESS_NAME: TeamSpeak.exe
LAST_CONTROL_TRANSFER: from 00499ba9 to 00495381
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
01d3feb8 00499ba9 00af0a01 000002e8 00b12744 0x495381
01d3fee4 0049a638 01d3fef8 0049a64b 01d3ff70 0x499ba9
01d3ff70 0041ba07 01d3ff84 0041ba11 01d3ffa0 0x49a638
01d3ffa0 00404212 01d3ffdc 00403d88 01d3ffb4 0x41ba07
01d3ffb4 7c80b683 00a8d720 01190748 01190000 0x404212
01d3ffec 00000000 004041e8 00a8d720 00000000 0x7c80b683
STACK_COMMAND: kb
SYMBOL_NAME: ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME: Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP: 0
BUCKET_ID: INVALID_KERNEL_CONTEXT
Followup: MachineOwner
So I guess to try and fix it do as I said above... unless someone can make more sense of the info above?
Ahh thanks, i use teamspeak when i play Battlefield 2 , so i can talk with the Clan.
I will reinstall it.
Many Thanks :D
