Trapped Ulnar Nerve
Status
Not open for further replies.
9 Sep 2008
If you’ve ever bumped your elbow and felt a tingling sensation down your arm into your hand (hitting your "funny bone"), you’ve bumped the ulnar nerve. But the ulnar nerve also can be the cause of more serious and permanent problems in the fingers and hand.
The ulnar nerve extends down the arm, across the elbow, and into the hand. It provides sensation to the little and ring fingers and activates many of the small muscles in the hand. You can actually feel this nerve as it passes behind the elbow and through a tight tunnel (the cubital tunnel) at the inside of the elbow.
The problem An injury to the elbow such as a dislocation or fracture can tear or inflame the ulnar nerve. The inflamed nerve can swell and become trapped in the cubital tunnel. This gives the condition its name, ulnar nerve entrapment. It is often also called cubital tunnel syndrome.
Prolonged pressure on the nerve also can be a problem. Bending the elbow stretches the ulnar nerve and puts pressure on it as it passes through the cubital tunnel, pressing it against the bone. This constant rubbing can damage the nerve’s protective covering (myelin sheath) or the nerve itself and disrupt the nerve’s ability to conduct messages from the brain. Gradually, the muscles of the hand start to weaken, so that it becomes difficult to open a jar or grasp a tool.
http://www.mconcannon.com/hand/ulnar-info.php
I'm certain I have a problem with the nerve in the elbow since I've got the classic symptoms of tingling and numbness in little and ring fingers. Seems to have been caused by resting my right elbow on the armrest of my chair while using the computer. Had it for a few days now and obviously a trip to the doctor will be necessary if things don't improve ...
Has anybody else suffered with this ? How did things work out for you ? :confused:
Happened to me the week leading up to handins in my second year of University. Having loads of essays and 3d modelling to do when I couldn't feel my left hand sucked.
I pretty much diagnosed myself reading online but went to the doctors anyway - in the end it just went away after handins once I started moving it around more. Had it for 1-2 weeks.
I have had this tingling sensation after resting my elbow on the desk at work for a while now, i will have to look into this a bit more :)
Status
