i just bought a gitzo travel series tripod for this sort of purpose but any old small carbon fibre tripod thats £150+ should do the trick
what is your budget?
Sub £50 would be ideal.
I've had a gorrilapod in the bag for years for just this purpose and it works fine, mainly gets used for taking timer photo's of me and the misses when there is nobody else around. I've not got a quick release as it's so quick to screw on and it happily handles my 5D mkii and Tamorn 28-75mm f2.8.
I've tried the bean bag/rucksack appraoch and the gorrilapod always produces better results with a lot less fuss plus it gan be used on all sorts of other ojects from trees to fence posts. I have a lovely set of the sun setting over Uluru taken with the gamera on the gorrilapod perched ontop of a slope topped post.
Exactly what I need to know, thanks
What GP model do you have?
I have an SLR zoom and while obviously it's no replacment for a full sized Gitzos for professional landscape work it is great on a holiday and has let me get some shots that otherwise would not have been possible.
Funnily I have th exact oposite experience with gorilla pods. I had a loan of he SLR version from a friend and found it utterly useless, the mirror slap would vibrate the entire thing. While a bean bag happily absorbs the vibration from the mirror. It would work much better on cameras with a mirror up lock which is miss g on my D90.
Everyones milage will vary, I was reminded how useful the gorillapod was on a recent trip to morroco when I forgot it and tried taking some snaps of me and the wife using the rucksack to support the camera which was a total pain!
A rucksack alone is a total pain, that is where the bean bag comes in handy because you can position the camera and get the angles you want easily, and then the bean bag absorbs the vibration from the mirror slap. Bean bags are used a lot by pros with big lenses as a method for dampening vibrations
Preumably a lot of the stability of a tripod comes from it's weight. So is a £150 950gram triopod going to perform any better than £25 1.5kg one?
I've been using a gorilla pod, but it's now broken. I always used shutter delay with it to prevent mirror slap.
