Travel Tripod
16 Oct 2016
East Lancashire
With a trip to Edinburgh and Rhodes coming up this year. Plus lots of other things I want to go a photograph.
I'm looking for a Travel tripod, budget £100 max and preferably something that will fit into my rucksack.
My Dslr isn't a big heavy thing Canon 200D
With 18-55 lens and 10-22.
Reccomend me some please.
It won't fit in your rucksack but I recommend the Benro TSL08CN00 Slim Carbon-Fibre Tripod with Ball Head.
Only 1kg, carbon-fibre and take up to ~4kg of load.
The one above is under 1kg, 33cm folded and will take 8kg.
I looked for ages and couldn't find anything better for the money.
I brought one of these after seeing your post on the new gear thread and it is very good. Packs down small and very light as well as being very well made.
