- 7 Feb 2004
Hi there,
I put this in here as it's more of a question about electricity than treadmills. I have just got a treadmill but when I turn it on it trips the socket. After I turn the socket back on the socket doesnt trip anymore but I cant get the treadmill to start.
I have used it once for about 30 minutes as a test which seemed fine but even that tripped the socket once.
SPECIFICATIONS:
Ground Effects impact absorption system
Speed : 0.5 mph - 12 mph
Incline : -2% to - 12%
Dimensions : 32"W x 76"L x 50" H
Weight : 265 lb.
Power : 120Volts (20-amp circuit breaker recommended) Can be plugged into a conventional wall plug in a home. 240Volts (20-amp circuit breaker & dedicated circuit recommended)
Workout programs : Quick Start, Hill Profile, Random Course, Interval Course, 10 Pre-programmed courses, 2 Custom Courses & Manual. Consol Readouts : Segment Time Left, Minutes Per Mile / km, Watts, Pacer Distance, Pacer Speed, Calories Per Minute, Total Calories,
Incline & Mets
I am using it in the garage? Is it under powered?
SPECIFICATIONS:
Weight : 265 lb.
Incline & Mets
