tREFI settings on AM5
22 Jul 2021
Belgrade
Where can i found trefi settings for strix b650e e gaming,is it available to change the values to end user or not?
using 7600x with bios version 0821 ComboAM5PI 1.0.0.3 patch A + D
I know on the X670E Hero, tREFI was introduce in bios version 0805.
Code:
ROG CROSSHAIR X670E HERO BIOS 0805
Version 0805
9.18 MB 2022/11/15
"1. Update AGESA version to ComboAM5PI 1.0.0.3 patch A + D
2. Improve DRAM compatibility
3. Improve System Performance
So I would suspect would have it but don't take my word for gospel.
no,its named different its not trefi any more on am5 now its under different name forgot now which one i can check later if you want
Not sure why it would be renamed something difference, as tREFI is the correct name for maximum average periodic refresh.
I can only speak for the X670E Hero, which I have manually set on mine.
refresh interval 65535 (am5 strix b650e gaming e) maybe on hero is different,i get what i want :)
