- 18 Apr 2004
- Milton Keynes, UK
Hey all,
I need to understand what to add to my existing mesh network. I'm using a tri-band Asus XT12 which is connected via a backhaul ethernet cat5 (if that is the correct term). I should have 2.4G and 2x 5G WiFi channels.
However, the ground floor and, more so, the basement cannot receive a strong signal... so I can either add another tri-band router node (possibly another XT12) or just a standard dual-band router node to add to the mesh network. I'll most likely be connecting up 2.4G devices e.g. smart cameras, and smart plugs. Ok budget as flexible.
I have no chance of wiring this up so questions:
Would this affect the speed and channels used?
Would I need another tri-band for more efficiency or would a dual-band be enough?
How would adding either node to the current network affect the current backhaul ethernet setup? Would it use the last channel for 5G meaning only 2.4G and 5G available?
Ideally, wiring it all up with ethernet is the best bet for efficiency, but it is not possible at the moment.
		 Did you set the transmit power on the WiFi channels? Can't remember if they are set to full out of the box or not. Where are the XT12's placed at the moment (i.e how many floors do you have)? I would have thought one on ground floor would reach the basement OK as for example. Cheers.
