Tri Band Mesh System?
27 Aug 2005
So i am currently using a Tenda Nova MW6 in my current 3 bedroom property but i find that sometimes the connection isn't as good and considering to upgrade to a tri band mesh system.
Is anyone here using a good tri band mesh system? I'm thinking of the Asus AX at the moment.
Can you describe your current internet? Speed/latency etc
And what is it you’re predominantly looking to achieve? Quicker internet? Better connection?
Would you be able to list the top 3 things, with number 1 being the most important? :)
Finally, what’s your budget?
