7 Jul 2011 at 11:19 #1 djkav djkav Soldato Joined 28 Aug 2006 Posts 3,003 There seems to be lots of Tri-Channel 1600+ DDR3 kits on here, but only Dual Channel boards (4 DDR3 slots) Am I missing something here? Surely using a 3 DDR kit on a 4 DDR slot board will disable the Dual Channel boost.
7 Jul 2011 at 11:25 #2 Mr. May Mr. May Soldato Joined 23 Apr 2009 Posts 3,473 Location Derby there for x58 platform which use tri-channel memory
7 Jul 2011 at 11:56 #3 djkav djkav Soldato OP Joined 28 Aug 2006 Posts 3,003 Mr. May said: there for x58 platform which use tri-channel memory Click to expand... Ah that solves that. So what about socket 1155 for SB, all I find on those is 4 slot boards? Last edited: 7 Jul 2011
7 Jul 2011 at 12:09 #4 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,555 That's a dual channel platform - so you'll need a set similar to this.
9 Jul 2011 at 18:24 #5 djkav djkav Soldato OP Joined 28 Aug 2006 Posts 3,003 Could you just use 2 sticks of the tri kit for 1155 SB boards? All DDR3 is the same sticks dual/tri channel?
9 Jul 2011 at 18:44 #6 Plec Plec Soldato Joined 19 Apr 2003 Posts 13,555 djkav said: Could you just use 2 sticks of the tri kit for 1155 SB boards? Click to expand... djkav said: All DDR3 is the same sticks dual/tri channel? Click to expand... Yes and yes - respectively. djkav said: Could you just use 2 sticks of the tri kit for 1155 SB boards? Click to expand... You could if you wanted to. If you break up a tri-set the two sticks that you use will essentially be matched pairs - same as a dual kit. Last edited: 9 Jul 2011
