Trident Z Neo CL14 3600mhz 8x8GB kit
24 Feb 2021
So I've pulled the plug today on my PC build, having given up on the GPU wait.
I have a Trident Z Neo CL14-15-15-35 (1.45v) 3600mhz 8x8GB kit that was going to go into two identical 5950x builds, but as this is now not happening, I'm left with this lovely ram with no purpose.
Should I sell it?
I'm not sure if it's rare/good enough (Samsung B Die) to keep and it still be useful down the line?, or
If it will be outdated by DDR5 in 12-18 months?
Thoughts?
Can you return it and cut your losses any further projects coming up ?
Cheers for the reply buddy.
No returns unfortunately, and it was a joint project between my brother & I so no other projects, we're both mac users, so the builds were purely gaming.
I was wondering if £200 for 2x8GB, or £400 4x8GB is reasonable or not, as I doubt many will be looking for 8x8GB (which cost £800).
Your looking at a very niche market your just going to have to try your luck but probably best to sell in 16gb kits
Where did you get a hold of these kits?
I think my current 2x16GB ballistix 3600cl16 is holding back my system performance due to being single rank.
Trying to find samsung b-die kits of similar speed/latency is proving impossible :|
I can't say buddy sorry, against forum rules. The e-tailer are the only people in the UK to stock the 8x8 C14 kit though, so if you find it - I got it from there.
I'd love to sell you a set from my 8-stick kit, but I'm pretty sure that's not allowed either :)
Ah that sux.
Well good luck with the sale, and ill try find the kit.
I doubt the ram is holding you back unless you game at 1080p since ram only effects performance when you’re cpu bound.
Yea its too easy to get suckered in to chasing benchmark scores!
I begrudge my low 3DMark CPU scores... but in games probably makes 0 difference.
