Tried to build a PC after 15 years and I am having a nightmare! Motherboard wont post :(
20 Oct 2002
London Town
I haven't posted here in a very very long time!
I decided it would be fun to build a gaming PC for my 11 year old daughter, and I am struggling to get the motherboard to post. I don't know whether it is the CPU or MB that is at fault or if it a bios issue.
Motherboard : asus prime a320m-k (used from ebay)
CPU : AMD Ryzen 3 3100 3.6 (used from ebay)
PSU : CiT ATV Pro 500W 80 PLUS Bronze
RAM : Corsair VENGEANCE LPX DDR4 RAM 16GB (2x8GB) 3600MHz (used from ebay)
GPU : SAPPHIRE Nitro + Radeon RX 580 8GB GDDR5 (used from ebay)
Storage : M.2 1Tb
I hope I have ordered components that are compatible with each other?
With the MB on the bench, with just the CPU/Fan fitted (no ram), and the bios speaker installed, the board powers up on, and the fan spins, but I don't get a beep of any kind. I don't have the GPU yet (in the post) so I can't see if it will load the bios, but I am assuming if I am not hearing a beep then it isn't posting?
I've checked the manual and I have both the 4-pin ATX and longer MB power plugs fitted.
I tried taking out the bios battery for 5 min to reset the bios but that didn't help. Is the CPU dead?
You want a 4 pin EPS plug, not ATX.
That's probably a dreadful PSU.
The motherboard may require its BIOS updating: according to the CPU support list you need version 5007. You should also check the CMOS battery.
Try with one stick of RAM installed. I think it should beep if you have no RAM but maybe you have the beeper the wrong way around?
Since there are no integrated graphics it might not initialise without it, so I'd wait until you have one.
As Quartz mentioned above, the shipping BIOS may not be compatible, since you have a 1st gen motherboard with a Zen 2 CPU.
