Hi guys, bit of help needed if you don't mind...
I've been running x3 6970's for a while now with x3 monitors. I've since "borrowed" a 4th monitor which I've installed above the middle monitor.
Issue is I can't get it to turn on in Windows.
I've got the monitors all plugged into the primary (top mounted?) card in my machine. X2 via DVI and x2 via Displayport. The 3 "current" monitors work fine, (x2 DVI and x1 DisplayPort), I added the 4th monitor to the spare DisplayPort on the back of the card (actually, I used a Displayport to HDMI converter as I don't actually have a Mini-Displayport to normal displayport cable).
Is there anything I need to enable / disable in Catalyst Control Manager or within Windows to allow the 4th monitor to turn on?
Many thanks,
Many thanks,
