hi there was thinking of installing windows 7 64 bit on my pc i currently have windows vista 32 bit installed.
just wondering will i have any isues having a 64 bit os and 32 os on the same hardrive?
another thing also, i try to install windows xp just now and all went well till the system reboot and did not load either os was expecting to see a boot list showing windows xp and vista but instead i got the message error reading disk.
i manged to boot from the xp cd again and remove the partition drive with xp and then put the vista cd in and repair the partition containing the vista os.
what im trying to say is what did i do wrong?
i did boot from the xp cdand install xp so dont know why it did not load xp or vista.
any advice welcome
thanks
bigman62
any advice welcome
thanks
bigman62
