- 22 Mar 2009
Can you help me out which triple channel memory are the best one for my X58 board i7 2.66Ghz @ 4.00Ghz oc. The reason I want a new memory because of ram slots can be easy fitted when my new Noctua NH-D14 cpu cooler (to avoid block ram slots with my old memory is well too high) cos my old memory ram is Corsair Dominator 6GB as it will be a big problem with new cpu cooler had arrive next week.
Which one is best one:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-169-CS
or
http://www.overclockers.co.uk/showproduct.php?prodid=MY-129-OC
Corsair XMS3 or OCZ Gold ?
I will promise to post back once I had the new triple channel rams with the new cpu cooler and see what temperature is like for i7 @ 4.00Ghz overclock with HT and turbo enabled with linpack.
or
