Triple Monitor Display Requirements.. ?
26 Aug 2011
Highlands, Scotland
I have been looking to move toward a triple monitor display, but I am not specifically sure what components I would need or what the spec of these components would be?
I currently have an Asus VG236HE 23" monitor, and would be looking to purchase 2 more 23" monitors. Maybe a pair of these:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-061-AS
I have dual monitors at the moment and I made the mistake of getting different resolutions. Are there any other tips out there or recommendations toward a specific screen?
Currently I use the nVidia GTX650 Ti and was looking to upgrade into the GTX770 range? I have been looking at this card:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-225-EA&groupid=701&catid=1914&subcat=1750
Does anyone know if this would suffice for a triple monitor display? Is it a matter of just having 3 x HDMI ports or 3 x DVI-D ports?
Thank you for your time
I would probably just use the one screen for gaming, then all three for general use.
Is there a lot more configuration involved for gaming?
Well, for gaming you would want a very slim bezels and preferably all monitors of same model.
I am going for 3 screen setup as well and was looking at those:
Asus 24" vn247h
Ilyama 23" xu2390
Ilyama 24" b2481hs-b1
They have very slim bezels. I heard some news that soon we may see some seamless screens again, but I wont wait to long. I want my rig fully up and running in 3 months tops.
Ahh that makes sense! Quite like the look of the Asus VN247H youve mentioned there, £20.00 cheaper as well!
