I have had a dual monitor setup for a while now and all has been good. At the moment I only use one of the monitors for gaming but I do use both in general windows use. The monitors that I use have been discontinued, I think for a while, and I have managed to pick up a third monitor cheaply.
I am looking to get the third monitor up and running and am a little unsure on how to proceed. My system is quite old now so it will probably not be able to run the latest games on all three monitors, but I would like the option to be able to do that on some older games.
My current spec is:
What would be the best way to go about upgrading so that I can use three monitors.
As far as I can tell I have two options.
Any ideas on what would be the best option, or if there is another option. I am not looking to upgrade the whole lot just now.
My current spec is:
- Asus P5NE-SLI
- Q6600 @ 2.4ghz
- 8GB Ram
- 550W PSU
- GTX 560 ti
- Buy a second 560ti and possibly a new power supply and run these in SLI. Not sure if this is possible on the P5NE-SLI?
- Buy a highish end ATI card.
