Triple monitor mount?
20 Feb 2009
Ashton-Under-Lyne
I have a Samsung T260 as my centre monitor, with a Viewsonic VX922 on either side, and am looking for a desk stand that can support all three. The viewsonics have vesa mounts, however the Samsung doesn't, but I remember seeing something somewhere about an adaptor that allows you to vesa mount it (although I can't find anything about it now) I'm not entirely sure on my budget yet, but if someone has an idea what sort of price it would cost (and has a product to show me) then I can decide if I'm willing to spend that much on it.
Thanks in advance
^ like this? $200 :eek:
Yea, I was meaning something like that, although that price is rather steep :eek: my pair of Viewsonic's cost me less than that :rolleyes:
You can get one similar to the above for under £100, though i don't think i can link to them due to competitiors etc, its the following you want:
EDIT: MDM06 Multi Screen Desk Mount Bracket, can be had for £70
You'd be very very hard pressed to find something cheaper, spent ages looking around for ones to use at work, the above make were the cheapest we found
EDIT2: actually it'd be £96 as you have to buy long arm pieces in addition to support larger monitors than 15" lol
