triple monitor queery
10 Apr 2015
airdrie, scotland
hello
not sure if here, the gpu section or monitors would be the best place so chose here.
basically would an nvidia 1060 be capable of running 3 monitors, 1 running most newer games at 1080p ( not maxed ofc ) one running a browser such as chrome and using the 3rd for using youtube clips at the same time
TIA
you could plug the one for gaming one into the gtx1060
and the other 2 into the onboard/motherboard gfx if you have that.
Shouldn't have any problems with doing what you want, have the same sort of thing for the better half but she is running on a GTX 980
Wartris
thnx im just looking at my oldest boys xmas and hes asked for a new build pc for csgo and such and wasnt sure if the gtx 1060 was any good or not for gaming
CS :Go uses about as much GPU power as a potato, its very light on acceleration.
A 1060 will sit there and paint it's toe nails while playing with no problem at all.
thnx for reply, so the gtx 1060 will be a decent bet then, meant to say it was the 3gb ones i was looking at as when you get to the 6gb pricing the 480 appears to be a better bet.
