Triple monitor question
20 Jun 2005
London..
Currently I have 2 monitors running from my x1800xt graphics card. I would like to add one more, how would I go about doing it? Can I just buy another cheap graphics card and connect it to that?
Thanks
Cool.
What about the second card? Can I just pick up a second hand x300 or x700 or something? Will Windows automatically set it up?
Thanks. Is UltraMon still the tool of choice to handle more than one monitor?
I think DisplayFusion is better now. Its about half the price, and was updated for Win7 much faster than UM was. There are a couple of things that it couldn't do that ultramon did, though I can't for the life of me remember what they are now.
http://www.displayfusion.com/Compare/
Check out the 30 day trial, should give you an idea if you want to buy it, certainly was an easy choice for me, been using it for ages now :D
