Hi all,
Looking for a bit of advice and would appreciate any help.
Basically i'm looking for three monitors for work purposes, mainly running spreadsheets/outlook/lot's of browsers etc. so nothing to intensive.
I have purchased a Matrox TripleHead2Go Digitial Edition (DVI) unit as I'd like the flexibility to switch between laptop/desktop.
The three key factors i'm looking for in the monitors are:
In terms of Screen Size I'd like something between 19"-24" - the Matrox website lists supported resoloutions as "Supports a maximum resolution of 3840x1200 (2x 1920x1200) or 5040x1050 (3x 1680x1050)" Would be great to have all three monitors with a res. of 1920x1200 so i could use two with the higher res (1920x1200) as and when needed and then switch to 3 @ 1680x1050 when running three makes more sense, however not sure if it's possible to get monitors that run and 1920x1200 & 1680x1050 due to aspect ratio's etc.
Thanks in advance for any help!
D
- Cost Effective (Max £150 each)
- Decent Brand (doens't have to be the best) Iiyama etc. With min. 3 year warranty
- Slim-ish Bezel
D
