Triple Monitor Rig
23 Aug 2014
Hi Guys,
I'm looking at getting a new pc which can handle a triple monitor set for playing games on all screens. Whilst I have built before my job means I don't have much time so I'll prob go for a pre-built one from OC.
Can anyone recommend a system for around £1500 which could do this (Not including the monitors, I will get the GF to buy me them for xmas ;))
If it cannot be achieved for around £1500 I would like to know what I do need to spend as well.
Thanks
£1470 if u can spare the extra get a i7 bundle
http://www.overclockers.co.uk/showproduct.php?prodid=BU-005-GI
What res will these monitors be? If its 1080p it should be easy (no need for 980's). If 1440p you may struggle a little, even with 2 980's (only a little)
Assuming 1080p..
This is ideal, under budget too, so you can contact OCUK (via the CS forum) and get a quote on building it for you..
YOUR BASKET
1 x Gigabyte Z97X-UD3H-BK - Devil's Canyon Core i7 4790K CPU & Motherboard Bundle **£35 Saving** £365.98
2 x Powercolor Radeon R9 290 PCS+ OC 4096MB GDDR5 PCI-Express Graphics Card £215.99 (£431.98)
1 x SuperFlower Golden Green HX 750W "80 Plus Gold" Power Supply - Black £82.99
1 x Crucial MX100 256GB SATA 2.5” 7mm SSD + 9.5mm Adapter (CT256MX100SSD1) £79.99
1 x Kingston HyperX Beast 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Kit (HX324C11T3K2/8) £71.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £61.99
1 x Silverstone Tundra Series TD03 Liquid CPU Cooler £49.99
Total : £1,229.86 (includes shipping : £12.50).
