Triple Monitor Set Up
7 Jan 2006
Hi -- I'm looking to get a three monitor set-up to run iRacing @ 5,600 x 1200 (or whatever it is for three 1900 x 1200 monitors). I'm looking to wait for the 7000 series but what is likely to be required to run BF3 at this resolution smoothly with all the bells and whistles turned on?
For that resolution, with everything turned to max including AA I would imagine something like 580 3Gb in Quad SLi. The recommended GPU req for BF3 is quite high after all :( (GTX560 or 6950 1gb). However if you're waiting for the 7000 series cards I would wait and see how they would perform.
Thanks guys -- I just played the BF3 beta @ 1920 x 1080 with 90% full settings and it was pretty smooth on my 470 GTX ... but understand that 3 screens is a new ballgame!
Ive got the 6950 2gb single gpu running on eyefinity with 6080 x 1080 or whatever the resolution is.... It runs ok on high with 45 - 55 fps but I do get the odd bit of screen tear.
Maybe over clock a 6950 or 6970 .... Or dual them.. Cnt really recommend nvidia as i dnt rele follow thre cards
