Triple monitor setup query.
27 May 2011
I have a DGM IPS-2701WPH Pro LED monitor that runs at 2560x1440, I would like to purchase another two and triple screen the setup and obviously play games on it.
I was wondering if any cards can do that right now, what kind of setup am I looking at? I'd preferably like the monitors to be at 1440p for each one whilst playing games.
If it helps, I'm more of an AMD / ATI guy.
Thank you for any responses you guys give.
Andy
I'm running 3 2560x1600 screens which is close to the res that you're looking to do. For playable framerates I needed Tri-sli Titans (original Titans) and even then I would have to turn AA settings way down to FXAA. At this res the higher AA settings are probably not needed anyway.
Most graphic settings would have to be dialled from Ultra back to Very High or High. It varies from game to game though.
These are the only results I have at hand.
Tomb Raider Benchmark:
Resolution: 7680x1600
Hair setting: normal
Shadow details: normal
AA: FXAA
Everything else at their max setting.
Min FPS: 62
Max FPS: 85
Avg FPS: 78
Crysis 3:
Level: Red Star Rising
Texture Detail: Very High
Game Effects from the Advanced Graphics menu: High
Filtering: 1x
AA: FXAA
GPU memory usage: Just over 4GB according to MSI AB.
Difficult to get the average but according to Fraps, the FPS was around the low 50's, occasionally dipping down to around 40 and below during heavy fighting scenes.
